427 Dart SHP short motors anyone
Old Sep 10, 2016 | 01:10 AM
aussiesteve's Avatar
Car: 1982 z/28 Right hand drive
Engine: 377 AFR195 750DP Solid cam 10.25:1
Transmission: TH/350 3200 stall spohn conversion
Axle/Gears: 10 bolt 3.42:1 Eaton Trutrac.
Got a stock 408Sbc bottom end with L31vortec top end 770 Holley ultra avenger big MSd pro billet and 1 3/4 full length headers.
with the cam fitted and the dished pistons it came up at 8.5:1 and it hauls *** on pump gas. And runs hard at 5500Rpm all day.
I have a bottom end that is more or less a 300hp setup and the top end could support 500hp.
The Dart 427 SHP looks like a good thing and i could bolt all me gear onto it and get e new cam ground to suit the compression..
I may have to talk to Dart about dished pistons as the ones that are stock in there short motor require 76cc chambers to keep it at 10:1 pump gas capable.
Has anyone bought one of these SHP 427 short motors. Apparently they come with either Scat or Eagle rotating assemblies depending on whats available at the time.
Old Sep 15, 2016 | 06:10 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Re: 427 Dart SHP short motors anyone
I have one in my car. Very happy with it. Eagle rotating assembly. HSR intake, 30lb injectors, AFR 220's, XR294HR can, 3600 stall. It moves out.
