No tach with external coil conversion?
Old Sep 20, 2016 | 03:43 PM
L6969's Avatar
I'm running a stock HEI distributer and just converted from an internal accel coil to external MSD blaster SS coil and have no tach.
I'm using MSD cap,rotor, modified dust cover, SS coil, and wires. No box. Car fires up and runs good, but no tach.
I've got both pink wires off the dizzy hooked up to pos on the coil and the brown to the neg on the coil. 2 black wires are not being used. Anyone know whats going on? Maybe a filter/resistor might be needed?
Old Sep 21, 2016 | 08:10 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: No tach with external coil conversion?
Take the 'tach' wire off the large cap and place it on the negative terminal of the external coil. If you used stock wiring for the external coil there should be a white pigtail already there to connect too.
RBob.
Old Sep 21, 2016 | 08:26 AM
L6969's Avatar
From the dizzy cap?
I have 5 wires on the cap two pink two black one brown. One pink one black and the brown are in a three prong harness the other pink and black are individual single prong harness. Don't see white? I assumed brown was my tach wire?
Old Sep 21, 2016 | 12:34 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally Posted by L6969
From the dizzy cap?
Yes, there is a terminal on the cap marked 'tach'.
I know little about the stock distributor wire colors. They varied too much over the years and models.
The white wire would be if you used the STOCK GM TYPE EXTERNAL COIL and CONNECTORS.
RBob.
Old Sep 25, 2016 | 11:16 AM
L6969's Avatar
I dont have the white wires, its a carb HEI.
I talked to msd, they are going to send me an inline resistor to try out but the guy on the phone didnt sound too sure about it.
Nobody has had this problem before?
Old Sep 25, 2016 | 12:34 PM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
As Rbob said, the wire that was originally connected to the "tach" terminal on the "in cap coil" HEI will need to be connected to the negative terminal on the external coil. If there was no resistor between the original HEI and the tach, you won't need one for the external coil setup. Some tachs require a resistor but that is tach specific, not distributor or coil specific. HTH!
CarGuyDennis
Oct 19, 2016 08:29 PM
Bald_eagle_machine
Aug 27, 2016 10:24 PM
84 1LE
Southern California Area
Aug 27, 2016 04:34 PM
AtlantaTA
Interior Parts Wanted
Aug 25, 2016 04:59 PM
