I can't keep my car running
Old Sep 22, 2016 | 07:34 PM
Toqwik's Avatar
I have a 91 305 tbi convertible. It has not left the garage in a year but I start it every week and it has stabilizer and fresh octane boost. It runs perfect for about 10 minutes. When it quits sometimes it stumbles sometimes it quits like the keys was turned off. Sometimes when it stumbles and dies it sounds like a short that I assume is the injectors trying to fire. I have even tried putting a screwdriver between the tbi and the linkage to keep the idle high and no help. I can the new try to restart and it won't start. I can let it sit 15 minutes and it fires right up and runs perfect again. This car is 100% original has all the pollution control and the cat is still there. I have replaced the ignition module but no change. This was my daily driver a few years ago and have never had an issue. I'm stumped, what are your thoughts? Thanks in advance.
Scott.
Old Sep 23, 2016 | 06:51 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: I can't keep my car running
Ignition control module would be my 1st assumption, but if you replaced it then I guess we'll look at some other possibilities.
Have you checked anything after it shuts off? You must lose something, fuel injectors stop firing, or spark plugs stop getting spark.
When it wont start, pay attention to your RPM gauge. Is the tach needle bouncing while you are cranking or it just completely still?
Old Sep 24, 2016 | 03:38 PM
Toqwik's Avatar
I was kind of thinking possibly the coil. Fuel doesn't seem to make sense because of how it quits. Sometimes it will run so rich it blows black smoke. As far as the tach, it pegs all the time. Like I said earlier sometimes when it quits it refuses to start. Let it sit 10 minutes and it starts like a brand new car. I hate to take it to someone but it can't be much wrong and I don't want to keep throwing parts at it.
m16a2r
Southern California Area
Oct 29, 2016 02:06 PM
Toqwik
Sep 28, 2016 03:35 PM
TKO500
Exterior Parts Wanted
Aug 27, 2016 06:21 PM
Mona23
Aug 26, 2016 04:00 AM
Roadrunner77Z
Aug 25, 2016 07:50 AM
