Identify these wires/connectors???
Old Sep 27, 2016 | 07:30 PM
SweetRed87's Avatar
Car: 87 Pontiac Formula 350
Engine: 5.7L
Greetings Thirdgen Brothers and Sisters. Just had a bunch of work done on my 87. Can anyone identify these three wires that did not get re connected???? I will post pix of the entire car when it's all done. I think you'll like it!!!
Behind master cylinder by exhaust manifold
Right in front of fan.
Old Sep 28, 2016 | 01:15 AM
Twin_Turbo's Avatar
Re: Identify these wires/connectors???
the ones with the eyelets are ground straps, either to the back of the cylinder head ot ro the firewall.
what colors are on the gray conector?
The blue wire goes to nothing on mine, it was factory taped into the wire loom. You can see it here
https://lh3.googleusercontent.com/Ye...20-h1080-rw-no
I remember there was some issue when I did ground it. Don't remember what it was but I taped it back into the loom. m
Old Sep 29, 2016 | 03:12 PM
SweetRed87's Avatar
Engine: 5.7L
Thanks for the info Twin_Turbo! So the blue one is an "extra" the black one is a ground. Here is a a better pic of the plug in question. It comes out of the same loom as the black ground wire.
Wires are red and white and plug into a plug. (if that helps)
Winchester
Feb 13, 2009 08:54 AM
89FormulaRoth
Exterior Parts for Sale
Oct 5, 2006 12:23 AM
breathment
Aug 9, 2002 11:51 PM
