Need help with oil leak
Old Oct 8, 2016 | 06:32 PM
bensbaby's Avatar
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
I have traced my bad oil leak to middle rear intake manifold...
now could it be bad dist gasket or am I gonna have to pull my whole tpi intake and re do the block to manifold with gasket stuff...I did this already in summer and its leaking...I obv used wrong stuff...if I have to can anyone point me to the best stuff for that spot.
ty
Old Oct 8, 2016 | 07:26 PM
Re: Need help with oil leak
Check the oil pressure sending unit.
Old Oct 8, 2016 | 10:15 PM
bensbaby's Avatar
Engine: 383 built
the unit as far as I can see is dry I had a light and it was running...
I don't know about where the unit goes into block...
I looked on pass side and it seems to be leaking right from back on intake manifold middle
man I just took apart everything to do valve springs and cam and hg....
I cant believe im gonna have to take it back off.
can anyone recommend me the bet rtv to use on oil because I used red high temp permatex something and its crap.
Old Oct 8, 2016 | 10:41 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I use Permatex Ultra Black around the coolant passages and for intake manifold end seals.
Z28FAST1
LSX and LTX Parts
Oct 22, 2016 10:54 PM
Anton Camaro
Alternative Port EFI Intakes
Oct 6, 2016 03:27 PM
Camaro29
Oct 6, 2016 04:10 AM
Ztbird
Oct 2, 2016 02:28 PM
ppj209
Sep 18, 2016 01:04 AM
