Clutch chatter
Old Nov 4, 2016 | 08:59 AM
jdanna's Avatar
Clutch chatter
Me and a buddy recently replaced the clutch on his 1989 305TPI 5 speed trans am.
Everything went in with no major problems - and seems to be working OK, but we are having a bit of an issue with clutch chatter.
Basically - the clutch grabs very high, and if the engine is under 2,000rpm it chatters like crazy from a stop. If you start at 2,000rpm or more its fine, and it shifts fine and doesn't slip under load.
At first I thought there could just be some oil left on the clutch or flywheel (though we did install a brand new flywheel, and cleaned it thoroughly before bolting it in).
What else could be causing this? I was thinking the hydraulics could be weak - I do have a new slave cylinder for it that I haven't installed yet.
Old Nov 4, 2016 | 09:26 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Clutch chatter
Check the fluid level
What brand of clutch?
Did he install the throw out bearing correctly that is a common mistake?
Usually any contamination can cause chatter. Other things to check would be the bell housing bolts or anything associated with the assemble.
Old Nov 4, 2016 | 09:28 AM
jdanna's Avatar
Re: Clutch chatter
I'll check the fluid level. it was a LuK clutch, pressure plate and flywheel.
I'm almost positive we installed the throw-out bearing correctly as pictured.
