Fuel pump relay
Old Nov 13, 2016 | 08:24 PM
Anthony0128's Avatar
Fuel pump relay
Can anyone explain to me the symptoms of a bad fuel relay ? Like the hell it could cause, cause I have a 92 camaro rs 305 tbi and I just switched out the fuel pump but I feel as if its not staying on when the vehicle turns on, the car will start but not stay on
Old Nov 14, 2016 | 08:51 PM
Vader's Avatar
Re: Fuel pump relay
The fuel pump relay is paralleled by the oil pressure switch. Since this backup path exists it would be best to monitor the fuel pump voltage to determine whether your suspicions are founded.
Old Nov 14, 2016 | 09:00 PM
Re: Fuel pump relay
Thanks for your reply, I actaully swiched the relay today and the problem continues. It's a 305 engine tbi. It cranks for a while before starting but then it's stays on for a bit and dies, the rpm drops and if I give it gas the vehicle dies right away. I really want to fix this problem and a smell of gasoline is also present. Anything would help point me in the right direction. I've swiched out the following
Water pump
Fuel filter
Fuelpump
Fuel relay
Cts
IAC
TPS
Rebuilt tbi
fuel regulator
New gas tank
Hoses
Vacuum lines
Spark plugs
Any help would be appreciated
Old Nov 22, 2016 | 01:53 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fuel pump relay
With all the parts thrown at it looks like your down to the ecm icm and pickup coil.
Old Nov 22, 2016 | 07:47 AM
Re: Fuel pump relay
What would you think it is ?
Old Nov 22, 2016 | 09:45 PM
Engine: Lb9
Transmission: M20
Re: Fuel pump relay
I really don't know what is causing your issue. From your explanations looks as if the engine is running real rich. Sounds like the cts is no so that should be good, same with the tps and ruling out leaking injectors.
The map sensor could be faulty ignition coil breaking down (weak spark)
Bad ecm, check engine light maybe on .
I don't believe the iat would make the engine so rich until the engine is warm.
Without having a scanner hooked up to the ecm to see sensor data it's hard to know what your issues is.
http://www.robietherobot.com/Storm/mapsensor.htm
This link shows 3 bar map output voltages based on altitude.
The feedback wire is light green at the map.
Old Nov 22, 2016 | 09:53 PM
Re: Fuel pump relay
I forgot to mention i threw on new injectors as well, the car had been sitting for 8 years so I'm sure it's going to have its difficulties. I did have it running for a while but I didn't drive it due to the fact that it wouldn't go pass 10mph or surpass 3000 rpm. Gradually the problem got worse and not the there's long cranking and hard start but it'll turn on then the rpms drop and the car shakes a lot then it turns off
