any plastic parts?
Old Dec 29, 2001 | 01:39 PM
Dan91Z28's Avatar
any plastic parts?
Does anybody know if there are any plastic parts in my distributor like under the pickup coil i'm guessing? Heres a exploded view of one almost the same as my l98 engine has:
http://www.metzcon.com/fbodymanual/2-14.htm
its a 91 z28, 350 tpi w/the coil off the distributor. thanks!
Dan91z28.
Old Dec 29, 2001 | 02:15 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
The only thing I can think of is that the pickup coil has a plastic cover on it, the moduel is bakelite...
Other than that I'm pretty sure everything else is some type of metal.
Old Dec 29, 2001 | 02:30 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There is one plastic piece I can think of under there...
It doesn't show on that drawing, becasue as far as GM is concerned, it's part of the housing. It's a sort of seal, to keep crankcase vapors from getting into the dist around the shaft. It looks alot like the rubber seals you see on "sealed" bearings. IIRC there's some felt or something underneath it.
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
