Speedo cable squeeking a tune
Old Dec 12, 2016 | 04:33 PM
Chuck's Avatar
How hard is it to lube the speedo cable on an 88 Iroc?
Or should I say... how do you do it?
Old Dec 12, 2016 | 05:34 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Speedo cable squeeking a tune
Reader's Digest version:
1. Remove the instrument cluster (disconnect the speedometer cable from the speedometer).
2. Pull the cable out of the casing.
3. Clean the cable of old lube.
4. Lube the cable with speedometer cable lube. On the speedometer end, leave 4"-6" unlubed (prevents lube from getting up into the speedometer).
5. Slip the cable back into the casing.
6. Re-install the instrument cluster (re-connect the speedometer cable to the speedometer).
