Code 36, L98, '88 GTA
Old Dec 23, 2016 | 11:51 PM
Beegeeskiller's Avatar
Hello, I have a 1988 GTA with the L98 motor in it, going on 80k miles. I have an intermittent code 36 SES light, and it comes with a rough idle and if I drive it a bit and I don't warm it up every three hours it has a hard time starting. If I let it sit overnight it starts decently well but still not perfect and still idles like crap (usually varying between 500-750 RPMs, or jumping between 2 and 3 lines on my digital dash). The idle gets worse when it warms up, but it has to stay warm or else I have a hard time starting it. I've tried using another MAF sensor, and I replaced the power relay, and it also has a new matching computer in it. I can't find a burn-off relay that will fit my '88. Anyone have the part number so I can pick one up at O'Reilly's? Thanks!
Old Dec 24, 2016 | 09:10 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Code 36, L98, '88 GTA
https://www.thirdgen.org/forums/tpi/...nces-they.html
Old Dec 24, 2016 | 10:47 PM
Thanks for replying. I've read through that thread before but I couldn't find a definitive answer. I looked through the post describing the wires from the relays to identify them and for my car it goes (from fender to engine) burnoff, power, then fuel pump. HOWEVER, my fuel pump is a square relay and my burnoff and power relays are oval and I can't find a part number for the oval one unless I missed it which is a huge possibility...
Old Dec 24, 2016 | 11:00 PM
Engine: Lb9
Transmission: M20
Last post of that thread !
ACDELCO 158240 15-18240
{#14089936, 14103304} GM Original Equipment
5-PIN OVAL SHAPE
Old Dec 24, 2016 | 11:20 PM
Oh, of course it'd be the last post. Thanks! I'll try it out
