Car won't spark
Old Jan 1, 2017 | 08:12 PM
antonov225's Avatar
Car: 1991 Z28
Car won't spark
Hey guys,
So, I just went through my car and replaced the fuel pump, fuel filter, spark plugs, plug wires, distributor cap and rotor and the ignition coil. I've pretty much isolated the problem to spark, as not even starting fluid will ignite. What could be causing the failure to start, even after I replaced all of that?
Old Jan 1, 2017 | 09:18 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Car won't spark
Icm and pu coil are the only two things left. Other than power loss to the icm.
