Need info on Pontiac battery cable
Car: 88 IROC-Z
Engine: 6.9L TPI(FIRST) 421ci
Axle/Gears: Ford 9" Eaton truetrac 3.50
I bought a Pontiac V8 battery cable set up to install and move the battery from the passenger side to the driver side. My question is can someone be so kind as to post up a engine bay pic or a diagram showing the OEM routing of the cables?
Or even type in here explaining the way the factory ran them.
Thanks in advance.
Thanks in advance.
Re: Need info on Pontiac battery cable
Down to the radiator support and across with the dual fan wiring to the opposite frame rail, then across the top of the frame rail back to the starter.
Car: 88 IROC-Z
Thank you Drew that's perfect.
