How do You Disconnect the Negative Terminal on the Battery?
Old Jan 21, 2017 | 12:18 PM
Vinscully50's Avatar
Car: 1986 Camaro IROC Z
Engine: LB9 305 TPI
I know GM cars have nuts on them that have to be loosed to disconnect the battery. But I can't get the nut to loosen or find anything that fits. I've tried an adjustable wrench and 3/8's wrench and nether will get it to budge.
I can't fit a ratchet down there either because the wheel well is in the way.
I know the battery isn't corroded because AAA replaced it a few months ago.
Old Jan 21, 2017 | 12:25 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: How do You Disconnect the Negative Terminal on the Battery?
They are suppose to be 5/16 head bolts. Use a box end wrench or ratcheting wrench.
If yours is damaged remove the positive cable and use vice grip pliers to remove the bolt.
Old Jan 21, 2017 | 01:42 PM
Engine: LB9 305 TPI
5/16s ended up working. It was on their super tight and it took me a few minutes but I finally got it.
I saw a youtube video where a guy with a GMC said it was 5/8s (I think he meant to say 5/16).
Old Jan 21, 2017 | 03:47 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
I use a large pair of needle-nose vise-grip pliers.
