Need help asap....or maybe I need a priest for this one
Old Jan 21, 2017 | 04:44 PM
Mattkovitch's Avatar
Car: Firebird
Engine: 305 tbi
Alright I'll make a long story short, was leaving my friends house after picking up a few parts he was selling me and I could seem to get my car (1991 firebird 305 TBI) to stay running. It stalled once in his driveway and it was foot to the floor to get it 5 minutes down the road to my house. That weekend I looked it over and discovered one of my fuel injectors was not spraying. I replaced both fuel injectors with some re manufactured ones from summit. I replaced, the distributor cap, rotor, ICM, spark plugs, ignition wires, and also bought a TBI rebuild kit to go along with the injectors. I pulled the TBI off and completely rebuilt it with the new parts. Put everything back together and went to start it and it ran kinda rough for 5 minutes or so. Sounded like I had a loopy cam or something. It would stay at idle fine but then after those 5 minutes it died. Then anytime after that I couldn't get it to idle or stay running unless I was holding the gas. Also the car won't start unless you floor it while it's cranking and a couple times I had fire come up from the throttle body, I'm pretty sure that was from the excess gas laying around the engine bay from the TBI rebuild. I blew it all off with compressed air and it didn't happen again. I'm at a lose, no idea where to go from here, bout to push it into the woods somewhere and say my goodbyes. This is just after I dumped 1500 in new body parts, and a full exhaust system. I've got class on Monday and my only other car just blew the head gasket, so I'm in quiet the jam
Old Jan 21, 2017 | 05:01 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Need help asap....or maybe I need a priest for this one
have you changed the fuel filter?
was it low on gas and humid? the reason i ask is because i experienced similar problems on a TBI once. it turned out to be the humidity created water inside the tank. scratched my head for days and replaced parts like you did. eventually i put fresh gas in it and it cleared up in 2 minutes.
i'm not a priest, but i am a minister. i can perform last rights if you decide to put her down. lol. but dont give up yet. probably something simple.
Old Jan 21, 2017 | 08:24 PM
Car: Firebird
Engine: 305 tbi
I was about to replace the fuel filter but a friend of mine who has been a tech probably before we had the wheel told me it probably isn't the fue filter bc a clogged filter would give me an okay idle a sluggish acceleration. I really just have no idea what to replace next, maybe fuel pressure regulator?
Old Jan 21, 2017 | 09:10 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
vacuum leaks? tape a fuel pressure tester gauge to your windshield and take it for a drive and see where your fuel pressure is while driving.
Old Jan 22, 2017 | 07:10 AM
Vader's Avatar
Agreed. A fuel pressure measurement will be important.
Old Jan 22, 2017 | 11:04 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Ignition coil?
Old Jan 22, 2017 | 01:38 PM
Car: Firebird
Engine: 305 tbi
It is undriveable. You have to hold the Rs at like 1000 to keep it running. As soon as you let off the gas it dies
