going nuts
Old Feb 10, 2017 | 09:15 AM
cball's Avatar
going nuts
what we have 89 iroc z Camaro 5.7 tpi, a friend brought car in for us to restore took engine out and had it completely redone, once we got it back in and got to where we could start it, every thing and I mean everything is brand new except the following EGR Valve, EGR Solenoid, and the ECM. we have no vac leaks my problem is the car runs rough, misses, and has rich fuel so bad that it burns your eyes. please help me we still have a lot to do before march 15 this is going to be a show car thank you so much
Old Feb 10, 2017 | 10:22 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: going nuts
If you didn't build the engine, how do you know it's been built properly?
Ignore everything that's been done and go back to basic diagnostics even it if means having the partially strip down the engine to check things. If the customer doesn't like that, tell them to take the engine and get it on a dyno to show that it runs properly first.
Just because someone else assembled the engine doesn't mean it's going to run properly.
Old Feb 11, 2017 | 07:23 AM
Vader's Avatar
Re: going nuts
Can you define "completely redone?" Did that list of "everything" include heads, valves, cam, timing set, intake, injectors, distributor, crank, re-decking, or what?
If the injectors were changed, what flow rate are they? What is standing fuel pressure? Where is the base timing set?
The more information we get, the better the guesses.
Old Feb 11, 2017 | 12:16 PM
cball's Avatar
Re: going nuts
the guy that redone the engine is a really good friend we where there when he done it I do believe we got it figured out its the alternator and the computer
Old Feb 11, 2017 | 12:17 PM
cball's Avatar
Re: going nuts
everything was redone and I mean every thing
