cruise control problem 1991 z28 tpi 350
Old Mar 18, 2017 | 12:53 AM
jeremy91z28's Avatar
Car: 1991 z28 5.7 tpi
Engine: zz4 tpi
Transmission: automatic
Heres my problem ive checked numerous wires and sensors and have power everywhere going to cruise control module but nothing coming out of it over to harness that goes out through the firewall but also i have no power coming from the red wire that is supposed to be the vss signal but my speedo works perfect any ideas guys?????
Old Mar 19, 2017 | 11:42 PM
Engine: zz4 tpi
Re: cruise control problem 1991 z28 tpi 350
Ok guys ive done a tone more testing ive got power everywhere now and everything from cruise switch to servo check out ive even bech tested the servo and everything checks out but cruise still wont work two wires have power to servo blue and green and can fill the servo click with car running and above 30 mph but servo dont suck in but all vacuum seems good any ideas guys??????
Old Mar 20, 2017 | 12:04 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
It's not clear from your posts:
1. Does the servo hold vacuum?
2. Have you checked for vacuum leaks at the brake switch?
3. Confirmed proper cable adjustment?
Old Mar 20, 2017 | 12:39 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Don't for get to check the vacuum line going to the vacuum reservoir ball (Orb) in the drivers fender
Old Mar 20, 2017 | 08:32 PM
Engine: zz4 tpi
Thanks for the help guys but ive checked all vacuums with vacuum gauge and everything seems fine ive checked the brake switch got power and vacuum there seems fine and after i let it run for a min i can pull the little vacuum hose off at the servo and it hisses so i suspect it is fine but i honestly dont know about cable adjustment i put it back in the spot where it had wear marks on the plate that sticks off of the servo im so lost ive read every post i could find and done every test i could find to to from power checks on everything from vss to ecm to cruise control module brake switch to servo and got power and vacuum but cruise wont do nothing....any advise would be great because im lost fellas and how do i adjust the cable???
