Mystery hole above oil filter
Old Mar 28, 2017 | 08:15 PM
turboguard's Avatar
Car: 1985 Pontiac Firebird Trans Am
Engine: 305 LG4
Transmission: 700R4 Automagic
Axle/Gears: No clue
Noticed this hole today when I was under my car...I prodded it with a screw driver and it seems to go all the way into the engine block. What is this hole for? Do I just need to plug it? There is another one to the left of it that is the same size, but it doesn't go through.
the hole<br/>
Old Mar 28, 2017 | 08:26 PM
Biledriver's Avatar
Car: 87 firebird 86 c10 90 mustang
Engine: 383 sbc
Transmission: 97 t56
Axle/Gears: Moser 12 bolt 3.73
Re: Mystery hole above oil filter
I think the hole with nothing in it was used to mount a pivot ball for a old style Z bar for a mechanical clutch. The one with the plug is oil pressur and needs to be plugged.
Old Mar 28, 2017 | 08:32 PM
Drew's Avatar
You mean the boss for a mechanical clutch linkage stud? Search Google for info on Z-bar clutch linkages and you should be able to find a photo of the stud.
Edit: Beat me to it... Replying to threads during commercials without refreshing the tab strikes again.
Old Mar 28, 2017 | 08:54 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The Z-bar was not the best way to mount clutch linkage but it worked well for basically stock, low powered vehicles at the time. One end attached to a ball on the block. The other end attached to a frame rail. Get a little too much torque twisting or a bad motor mount and the clutch linkage could bind or break.
Lots of old holes still cast into the blocks that many people don't know what they're for. There are 4 threaded holes on the front of the block also. Two on either side of the balancer. These holes were for the original front motor mount.
Old Mar 29, 2017 | 12:16 PM
Biledriver's Avatar
Engine: 383 sbc
I use the top hole on the pass side by the balancer with a longer bolt to hold the fuel pump pushrod in place while I change fuel pumps.
Old Mar 29, 2017 | 01:07 PM
turboguard's Avatar
Engine: 305 LG4
Axle/Gears: No clue
My OCD just cant allow these holes to go unfilled, time for some nice flange bolts!
Old Feb 22, 2022 | 06:10 AM
Hunter Zill's Avatar
Car: 1991 Trans am
Engine: 5.7
Transmission: 4L60
the hole<br/>
Do you know the thread pitch of those holes that are above the oil filter in the block?
