AFR valve seal removal question
Old Apr 8, 2017 | 12:15 PM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
AFR 210 heads with 8mm valves. Is there anything special or different about AFR head valve seals? I am trying to remove mine and they don't want to come off. I have always just pried them off in the past with other heads but these don't want to let go.
Old Apr 9, 2017 | 12:36 PM
Vader's Avatar
Re: AFR valve seal removal question
Are you certain the valves are 8mm and not 11/32"?
Old Apr 10, 2017 | 07:02 AM
Car: 89 IROC
Engine: 6.8 HSR N2O
Yes, they're 8mm. I figured it out they are just harder than most due to serrations or grooves on the outside of the valve guide. Holds the seal firmly. I used two Z shaped flat blade screwdrivers as levers and pried them back and forth and they finally popped loose.
I replaced them with viton seals for LS and they went on fine. Even though the AFR seals are listed at .530 the LS fit tightly on the guide and went down far enough to give good retainer clearance.
