XR270HR + Carb Stock 305 Vortec + M28 T56
Old Apr 11, 2017 | 12:09 PM
10SecondS10's Avatar
Curious to hear some feedback about running a Comp Cam XR270HR in a low mileage Stock 305 Vortec out of a C1500.
Cam Specs; http://www.compcams.com/Technical/DynoSheets/XR270HR-10_001.asp
Stock 305 Vortec block
Stock 305 Vortec Heads
Roller Rocker Tips
AED Holley 650cfm Mechanical Carb
Air Gap Dual Plane Intake Manifold
Comp Cam XR270HR
Hedman Longtube Headers Ceramic Coated
Brand New A1 Cardone Distributor Rotor Cap Kit
Brand New AC Delco plugs
Brand New Oil Pan
Electric Fans
Running a M28 T56 6 Speed
Going into a 85 Chevy S10
Weighs 2900lbs with stock motor/trans
I pieced this motor together when I just started learning about SBC's
Now after a year of reading and planning different builds I'm considering selling everything and starting fresh.
I want to build a MPG beast and obviously this is not the combination for this but still would like to hear feedback on the current setup.
As is the motor and trans are sitting in my truck on mounts not hooked up, and everything is for sale online. I have the chance to sell everything on the list Friday, somebody wants to come buy everything in 1 shot for $800 not including the carb, t56, or electric fans.
Old Apr 11, 2017 | 12:18 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: XR270HR + Carb Stock 305 Vortec + M28 T56
Did one in a stock rebuilt 350 L98. Ran strong. Think it will be nice in a 305. Good power band
Old Apr 11, 2017 | 12:35 PM
Nice! I got it off a guy running a 350. Any reason this would be too much cam for this 5.0L? Does a cam like this, with my current set up, hurt my MPG?
Also I should've mentioned earlier that my truck has 3.08 gears stock. I was considering swapping 3.73's or 4.10's but probably the 3.73 for fuel effiency.
Old Apr 11, 2017 | 12:50 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Eh smaller would be better for mpg but a good tune it should still do well since it's small cubes
