383 or 377 Pulling 15" or more Vac @ Idle
Old May 2, 2017 | 01:23 PM
Ja85z28's Avatar
Axle/Gears: 4:10
If you have an engine that meets the description above? Please share your cam specs.
Thank you
Old May 2, 2017 | 07:01 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 383 or 377 Pulling 15" or more Vac @ Idle
Not that difficult with a 1000 rpm idle and decent sized cams. Mine was a 383 with a 230/245 109 lsa idling at 1000-1100. Got close to 14".
Tuned a 383 afr headed deal with a baby 224/230 113 and it was around 15-16" with a lower idle speed 800-850 ish.
Proper fuel mixture and timing can be the difference in a few inches vacuum
My low comp big head 400" turbo motor idle 12" with a 950-1000 rpm idle with a big 246/252 .640" 113.5 lsa cam. Pretty big cam
All hyd rollers to give you an idea
Old May 2, 2017 | 07:03 PM
Ja85z28's Avatar
Axle/Gears: 4:10
Thank you
Old May 4, 2017 | 07:18 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
232/240 @ .050 roller on a 110° LSA installed on a 106° ICL was about 14 in/hg @ 950 rpm in a 10.5:1 TPI 383 in my old TPI G20 van. I ran that setup with both a 7730 MAP TPI ECM and a LS 0411 PCM with Vortec 5.7 electronics. Just swap the vacuum booster for a hydroboost and forget about it. I did it in both my G20 and Express vans. The vacuum a/c stuff and vacuum cruise control worked just fine with a good sized vacuum canister. On the old G20 the brakes also worked well with a canister. The hydroboost just worked better than the vacuum booster ever did even with 22 in/hg from the old stock 305.
Idle timing advance can make a huge difference in the idle vacuum as well.
I have a Lunati 218/228 on a 112° LSA in my 350 Express van and it pulls about 18 in/hg @ 750 running at 30° BTDC. The 0411 and idle spark variation alont with DBW throttle body keep it sounding nearly stock at idle.
Old May 4, 2017 | 08:43 PM
NoEmissions84TA's Avatar
Not a 383 but 334 (same 3.75" stroke but in 305 block).
Crane Powermax 2050 HFT - 14" at idle 216/228 112/107 .484/.512 (1.6) (CCC QJet).
ISKY 264 Mega HFT single pattern 214/214 108/108 .480/.480 (1.6) (M4ME QJet). 15" at idle
