Power steering gear kit
Old May 4, 2017 | 11:32 PM
Hal54's Avatar
Car: 1989 Iroc
Looking for knowledge. I own a 89 iroc with FE2 suspension. I have ordered a rebuild kit from " Edelmann, part # 8780. Looking at the kit there is not the square gasket for the side cover. They say it has been upgraded to an o-ring which is in the kit. I am a little apprehensive as I do not see a 0-ring groove on the cover or the mating body. I would like to keep this unit as I have owned the car since new. Does anyone have any experience or familiar with this upgrade. Thankyou thirdgens.
Anyone ?
Last edited by Hal54; May 5, 2017 at 09:33 AM. Reason: I believe " the truth is out there"
Old May 5, 2017 | 04:45 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Power steering gear kit
I'm going to guess that the Edelmann 8780 is for a steering gear that has a snap ring side cover, not a 4-bolt side cover.
Old May 5, 2017 | 05:47 PM
GeneralDisorder's Avatar
What's wrong with the box? Leaking? All the kit addresses is seals and gaskets.
GD
Old May 5, 2017 | 07:56 PM
Hal54's Avatar
Car: 1989 Iroc
After start-up the steering is tight until I move it back and forth a couple of times them it is normal. I have owned it since 89 and I figure the seals and bearings are due for replacement . This could be the cause of this issue.
Old May 5, 2017 | 07:57 PM
Hal54's Avatar
Car: 1989 Iroc
The cover is four bolt not snap ring.
