oil pressure gauge stays maxed out
Car: 1991 Firebird, 1997 3000 GT
Engine: V6
Transmission: Auto... 5 speed manual
Axle/Gears: stock
Goes all the way over after starting. Returns ot zero when turned off
Sending unit ??
Motor run OK...
Thanks Ed
Sending unit ??
Motor run OK...
Thanks Ed
Engine: V6
Axle/Gears: stock
Re: oil pressure gauge stays maxed out
Was thinking that, myself.
Time to jack it up and breakout the VOM....
Sending unit wire is unplugged
Short = 0 on the gauge (same discipline as an idiot light)
Plug the wire back in, most likely won't need the VOM.
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
it may be the sending unit too.. pretty cheap to buy new. i had to replace mine last year when the oil pressure guage was all the way to the right.
