Ignition cylinder stuck
Old May 27, 2017 | 08:50 PM
Nick Gallegos's Avatar
Car: 1986 Camaro Z28
Engine: Lb9 305 Tuned Port Injection
Transmission: 700-r4
Im replacing my ignition cylinder for my 86 z28 and ive done everything to pull it out but it is still stuck and it looks like there is a piece of metal from the cylinder to the mechanism. What can i do?
Old May 28, 2017 | 12:51 AM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Ignition cylinder stuck
You have to remove the steering wheel, the lockplate and the turn signal switch to gain access to the screw holding it in. Can get tools to remove those parts at the auto part store (steering wheel puller and lock plate remover)
You'll need a small pick or screwdriver to get a lock ring out of it's groove also.
Helpful if you have some kind of manual for your car
Not hard, just takes a little work. Be careful when removing or replacing any screws. You don't want to be dropping them in the column or you'll create lots more work
Old May 28, 2017 | 03:52 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
As mentioned, you will need this.
Don't even mess with it without this tool.
The snap-ring is under a lot of pressure and getting it out is a nightmare without it.
Getting it back in is no pick-nick ether.
You should be able to rent it at a chain auto parts store.
Just give them some cash or card and you get it all back when you return the tool.
= http://www.autozone.com/loan-a-tools...ver/112102_0_0
Old May 28, 2017 | 09:26 AM
Vader's Avatar
Perhaps this will help - Specifically Item 16:
Old May 28, 2017 | 07:57 PM
zed-028's Avatar
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
+1 on this, i didnt have one or access to one.
that snap ring drove me insane for about 3 hours. having a friend holding the main shaft with a really tight set of lockjaws (vicegrips) and pulling outwards while you try and replace the ring can make it easier.
Old May 29, 2017 | 08:43 AM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
No it won't, this is terrible advice and doesnt even make sense. The spring is compressed against the shaft you're pulling on. Pulling it does nothing unless you're strong enough to stretch the upper steering shaft itself.
Old Apr 29, 2018 | 05:27 PM
Ive removed everything that needs to be removed but it is still stuck in the column.
Old Apr 29, 2018 | 07:20 PM
Drew's Avatar
It's been nearly a year man. At some point you just get another column, or seek the help of an expert.
Old Apr 29, 2018 | 07:33 PM
Lurbie's Avatar
Car: 89 Camaro
