K12-600-4 comp cam
Old Jun 5, 2017 | 02:29 AM
Murdermaro's Avatar
K12-600-4 comp cam
I just installed a k12-600-4 comp cam on my 1982 camaro with my sbc 350 it has a edelbrock intake edelbrock carburetor edelbrock air cleaner and 2,800 stall torque converter and 2.73 gears but it has stock heads and stock block and the car runs really bad when i floor it it just bogs and back fires i checked the plugs and everything is fine but the car just doesn't run right at all can anyone please help me
Old Jun 5, 2017 | 03:03 AM
clubber's Avatar
Car: '92 RS
Engine: 5.0TBI
Transmission: TKX
Re: K12-600-4 comp cam
Start checking timing. Cam AND ignition timing. The rest is mostly the same and should work relatively well even if off perfect tune parameters.
Old Jun 5, 2017 | 04:02 AM
Murdermaro's Avatar
Ok ill check that out in the morning as soon as i have some time
