Low Voltage to Fuel Pump
Old Jun 5, 2017 | 08:03 AM
Golfvette's Avatar
Car: 87 Iroc Camaro
Engine: 350 Vortec TPI
Transmission: T56 Magnum
Axle/Gears: 10 Bolt 3:73
My 3 month old Walboro pump is making a very loud noise, almost like its cavitating. It all happened when my battery went dead and I jumped the car to get it started. After repeated cranking and it not starting, I decided to replace the battery. This is when it would start and run for a few seconds then turn off, and the fuel pump would make this loud noise. I found out I'm only getting 8 volts to the fuel pump! Why am I only getting 8 volts to my fuel pump? Is my fuel pump relay bad?
Please help!
87 Camaro tpi
Thanks in advance!
Old Jun 5, 2017 | 10:45 AM
jay123's Avatar
Car: 1991 Firebird
Engine: 5.0 TBI
Re: Low Voltage to Fuel Pump
Try replacing the relay first. then re-test.
