Fuel Tank Vent Valve, where to buy?
Car: check
Engine: check
Transmission: check
Re: Fuel Tank Vent Valve, where to buy?
NLA. Can find one in the JY that may be in decent condition. They can also be opened and cleaned.
RBob.
RBob.
Car: 85 IROC
Engine: ls1
Transmission: t56
Axle/Gears: ls1 rear with 3.23
I needed the same valve, could not find it anywhere. I put a universal valve on . I would reuse that one to keep the correct part. disassemble and clean while u got it out. it looks like just the top part broke, that just holds it in the bracket. lines are pretty stiff it should stay put, if not zip tie it.
