Any suggestions on how to give my car some of its oomph back?
Old Jul 7, 2017 | 03:12 AM
GxRxIxZxZ's Avatar
1987 2.8 6cyl. First I know it's only a 2.8 6 cyl but I feel like it doesn't have the get up and go that it should. Any suggestions on how I could get it up to speed with out spending thousands onafter market stuff?
Old Jul 7, 2017 | 04:38 AM
Drew's Avatar
Re: Any suggestions on how to give my car some of its oomph back?
Strap rockets to it? Load it into a catapult? Giant magnet mounted to front bumper - tail faster car. Giant rubber band, think sling shot. j/k
Has it ever felt better? Because an anemic V6 in a 3400lb car isn't going to have much get up and go. It's not quite hold the gas to the floor and bust out your sun dial to measure the blistering performance, but a 2.8L isn't remotely as peppy as any V6 built in the last 20 years. An early 90's 3.3L powered Dodge Caravan will lay an ***-whoopin' on a 2.8L thirdgen.
It's hard enough to get more performance out of a V8. Strongly suggest proceeding with caution.
Old Jul 7, 2017 | 06:56 AM
baker440ex's Avatar
Car: 87 Z28
Engine: Roller 305 LG4
Transmission: NWC T5
Axle/Gears: 9 Bolt 3.27 LSD
Cap and rotor will do wonders if they have been changed in awhile. Fuel filter usually makes a noticeable difference too
Old Jul 7, 2017 | 07:38 AM
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Really, it probably has all it is going to get. The 2.8/3.1 are great motors for daily driving. They are reliable and easy to maintain, but not powerful at all.
Even doing cam/heads won't help much there just isn't a lot to work with.
If you are really set on keeping the 2.8 I would look into the V6 subform, a few of us have turbocharged our cars and had good results. Worth a look!
