Building a 350
Old Jul 14, 2017 | 11:50 AM
HellHound's Avatar
Car: I drive trans am. Duh
Engine: Yes, I have one in the trans am
Transmission: I have one of those too In trans am
Axle/Gears: In the rear of trans am
Building a 350
So I have picked up a few blocks. And I have one that is a vortec. Good heads. what I am stuck on is the the intake. They are pricey. And going vortec I would be stuck that way. I have been looking at the Edelbrock and stealth ram.
Also I need to make a choice on a cam. I have been looking at the voodoo line. The rollers are pricey but I do have the stock stuff. I know that there are limits but I don't know what I am looking at on some of the stuff. I'm an import guy. Also I plan to boost later down the road. So I need to stay efi. What do you guys recommend? Thanks
Old Jul 14, 2017 | 12:03 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Building a 350
Step one separate roller from non roller blocks.
Step two toss out non roller or sell them to someone who wants to "keep it old school"
Now that you have that finished what are your goals. Vortec heads will make 400HP NA with some spring work and a decent cam. Otherwise use the block and bolt any heads you want onto it.
What heads do you have? What is your budget?
Any heads you reuse get them check for cracks and cleaned up at a local shop. Probably should bring the block while you are at it.
You may also want to look into an alternative EFI like fast or sniper and price that vs aftermarket TPI.
As for the cam comp cams XFI is a great line of roller cams to stay EFI
Old Jul 14, 2017 | 12:22 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Building a 350
Victor efi vortec intake plus elbow to ls style tb
edelbrock pro flo xt is nice as well.
Nothing is really cheap in efi but its worth it
Old Jul 14, 2017 | 09:32 PM
HellHound's Avatar
Re: Building a 350
One of the blocks is old school. One is a 90's third gen. And the vortec. So one two piece and two one piece. The heads are the stock 350 and I have the vortec heads.
Price does have a factor to a certain extent. But I dont want to cheap out. I have not paid a whole lot for what I have so far. Like the vortec was 60 on a stand, it came with some spun rods, but I picked up a good crank for 40.
The thing is that if I have the studs done seats and guides I'll be stuck with those heads for some time do to the Intake. I have thought about the elbow idea on the intake. It still puts me around the range of a good intake. Intakes I'm looking at are 'Brock pro flo xt and stealth ram.
Old Jul 15, 2017 | 10:28 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: Building a 350
Rebuild either vortec block or the roller thirdgen block. Refresh the vortec heads. Use them
Run roller cam around these specs: 224 deg .563 lift 108-109 lsa. Xfi custom cam
Either stealth ram or pro flo. It will make 400 hp +
Old Jul 17, 2017 | 10:16 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Re: Building a 350
Gm vortecs dont have screw in studs? High lift cam he may need em, there goes $
Old Jul 17, 2017 | 01:31 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: Building a 350
Yes he will need them but the heads should be refreshed anyway so couple hundred bucks wont kill the project
