Cam break-in lube for cam gear on new distributor?
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Hey all going to install a new dizzy on my 88 tbi. On the instructions with the new part it says "apply a liberal amount of cam break-in lube on the cam gear of new distributor. Failure to do so will result in premature wear of the distributor gear against a roller camshaft."
What cam break-in lube should i use with my new distributor?
Thanks all!
Edit: would Comp Cams 152 lube work?
Thanks all!
Re: Cam break-in lube for cam gear on new distributor?
We use Amsoil assembly lube. It's about $6. It looks pretty much the same as the comp stuff. Red, thick, and sticky.
GD
GD
I cant seem to find the Amsoil assembly lube, but as you state this lube i stated would work correct?
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
any moly lube you find in an auto parts store will work fine
honestly once that dist starts spinning its drenched in an oil bath.
Turning mine over by hand adusting lash gets it soaked.
