Help with some lines?
Old Aug 6, 2017 | 10:35 PM
91GTABIRD305's Avatar
Car: 1991 Pontiac Firebird Trans Am GTA
Engine: 5.0 TPI
Transmission: 4 Speed Automatic
Line comes from the body. Where does it connect?
What is this and where does it connect?
just trying to re do the top part if the intake manifold. If anyone has any diagrams of where all the lines connect and where they connect to the plenum as well as what hoses connect to the throttle body and where they come from? Thank you so much! Sorry but this is a learning process for me
Old Aug 6, 2017 | 11:29 PM
Drew's Avatar
Re: Help with some lines?
The widget that bolts between the coil and the intake is the EGR solenoid. The short tube goes to the EGR valve, the long one goes to the bottom of the throttlebody.
Edit: The 90* fitting is the vacuum feed to the HVAC system, it goes to T with the vacuum line to the vacuum reservoir/cruise servo. The other leg of the T goes to the plenum next to the MAP sensor and fuel pressure regulator.
No decal on the bottom of your hood?
Old Aug 7, 2017 | 01:11 PM
Engine: 5.0 TPI
Ill check, where would it be located at?
Old Aug 7, 2017 | 01:29 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
