What makes your RPMs increase?
Old Jan 2, 2002 | 10:15 PM
UVA3rdGen's Avatar
How does your motors RPMs actually increase? I know there is more to it then just opening the throttle becuase little briggs and straton motors run WOT all the time and you can still adjust the RPMs. What fundemental am i missing here?
Old Jan 2, 2002 | 10:56 PM
breathment's Avatar
lawn mower motors dont run WOT all the time, when u adjust the thingy, towards the rabbit or the turtle, it moves the throttle plate in the carb. same thing with a car engine. when u press the gas, it opens the throttle, and since the air inside the intake manifold is kept in a vacume, air gets inside, and more air means more explosion\fire inside the combustion chamber, meaning more power pushing the piston harder, making it move faster. u let off the gas, the throttle closes some, and less air is alowed to enter, vacume increases and less air to the combustion chamber means less power.
Old Jan 3, 2002 | 01:55 AM
Gta-Paladin's Avatar
I sure hope your third gen doesnt have a briggs and straton that would suck
Old Jan 3, 2002 | 07:19 AM
82camaro's Avatar
Car: 82 camaro SC
Your B and S lawn mower has a governor that keeps the rpm at a specific level. When the throttle is on the rabbit, the governor is at it's maximum rpm(the throttle isn't open that far when it's not under load). Under load, the throttle may be open all the way.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
customblackbird
Aug 15, 2021 10:16 PM
theshackle
Sep 17, 2020 08:26 AM
forstral
Aug 19, 2015 03:20 PM
Jake_92RS
Aug 17, 2015 09:42 AM
