86 IROCZ 35 twin turbo headers
Old Sep 22, 2017 | 07:05 AM
coren's Avatar
I have a 1986 Camaro IROCZ with a 350 sbc hooked up to twinturbos. The header on the left side originally purchased did not fit due to thesteering shaft. I attempted to modify this header and frankly made an absolutemess. I have had to remove this header 3 times due to leaks as a result of theinadequate welding. I would like for a company to build a new header (steelis fine as I wrap the pipe) for this using the modified existing header.It works and clears everything but is simply so full of welds that the 4th timeI remove it I want to go back with a product that is free of the many welds.Can anyone provide a reputable vendor who can take this header and make a new one using the example?
