Help, what should I do next after fuel pump replacement doesnt help start
Old Sep 29, 2017 | 08:12 PM
Fonso89's Avatar
Car: 89 Camaro IROC-Z
Engine: 5.7L/TPI
Hello guys im new to this page and to the 3rd gen world since I just bought this car off of my uncle thats had it in the garage forever and Hes never bothered to mess with it so I bought it, im having some issues with an 89 IROC with the 5.7 I tried to start it at first but all it did was crank and no start so one of my friends told me to check a little valve to see if I was getting fuel (i dont know the name of the valve) and I checked it there was no gas. I also couldnt hear the fuel pump buzz when I turned the key to the on switch so I changed the fuel pump and the fuel filter, now fuel shoots up when I press the little valve but all it does is just crank and no start like before I was going to change the fuel regulator to see if maybe that would help start? What do you guys think?
Old Sep 29, 2017 | 08:21 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Help, what should I do next after fuel pump replacement doesnt help start
What's the fuel pressure at the schrader valve ?
Got spark and injector pulse ?
Old Sep 29, 2017 | 08:28 PM
Fonso89's Avatar
Engine: 5.7L/TPI
Yeah I checked my distributor and spark plugs and I got spark, Im going to have to check the pressure on the Schrader Valve though.. Do you know what It should be at by any chance?
Old Sep 29, 2017 | 08:30 PM
Engine: Lb9
Transmission: M20
Tpi 43.5 psi, if that's ok sounds like your injectors are plugged.
Old Sep 29, 2017 | 08:35 PM
Fonso89's Avatar
Engine: 5.7L/TPI
Does that mean clogged?? And If so is there anyhing I can do to unclog them or should I just replace them?
Old Sep 29, 2017 | 08:54 PM
Engine: Lb9
Transmission: M20
Plugged clogged either, you can have them serviced or replace them. If they have a grey body on them definitely replace them. You can check injector pulse with a noid light.
