Very confused???
Very confused???
Okay so i got a 92 rs camaro the vin and hood all said its a 5.0 305 L03 that has had a stealth ram intake put on it and has a 5.7l 350 ecm and a 5.7l 350 camaro performance chip but it was from a 95 or a 97 i think and it also has headers and its running really rough and blowing a little bit of white smoke so i got under it n found out its a 627 cast so what kinda issues could i have from it being a 305 block with 350 performance parts on it and could it be the cause for it running rough and bogging down new to restoring have only tinkered n fixed anything that broke on my cars or family and friends but new to diag and not to sure where the hell to start with this thing or just rip the motor out sell it n start new
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Very confused???
94-95 f body ecm service 16181333 or 16188051 are flashed based. You must have another ecm and a memcal.
Engine: Lb9
Transmission: M20
Is the white smoke give a gas smell ?
Any identification on the injectors (body numbers )
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
White smoke is usually coolant in the combustion chamber.
