Lost power! bogging? Goes/Comes
Old Oct 22, 2017 | 12:57 AM
PURPLE Z28's Avatar
Car: 1992 z28 purple orchid
Engine: 5.7
Axle/Gears: 373
1992 z28 camaro, 5.7l V8
Turn key, fuel primes, crank it, roars to life, does great
about first 20 minutes or mIles (depending on the trip, power is present, it's responsive as hell
anything after that it's a gamble of wether it will do this or not, but after that 20 minutes or miles, when accelerating it will bog down, more acceleration will get it out of this "rut" but it's not pleasant to the ears or feel.....it does this in 3rd gear I believe, when at low speeds it goes back to being non-existant, and after being accelerates out of its "rut" on say the turnpike, it slowly returns to normal driving
...I've replaced the fuel filter, I plan on checking pressure soon, stand alone, and will try to get some tests while it does its thing
anyone experience this too? any info helps
Old Oct 22, 2017 | 12:00 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Lost power! bogging? Goes/Comes
Still have the stock Multec injectors installed? If so replace them.
RBob.
Old Oct 22, 2017 | 07:48 PM
PURPLE Z28's Avatar
Engine: 5.7
Axle/Gears: 373
RBob.
What do you recommend, I've heard injector run pretty expensive
Old Oct 22, 2017 | 07:55 PM
1988 Iroc 5.7's Avatar
Car: 1988 Iroc
Engine: 5.7 TPI
Axle/Gears: 9 Bolt 2.77 Posi
Contact South Bay Fuel Injectors. They are a site sponsor and are a regular here on the boards.
Old Oct 23, 2017 | 01:39 PM
PURPLE Z28's Avatar
Engine: 5.7
Axle/Gears: 373
just find their site online? or how do I get ahold of them through here?
