Car runs rough after valve cover swap. I think I killed my ecm
Old Oct 22, 2017 | 08:22 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
Swapped valve overs for some edelbrock valve covers. During the swap I did something I almost never do I forgot to disconnect the negative battery terminal . So when I was taking the valve cover off it touched the positive cable nut that is on the back side of the alternator. It was sparking for about 5 seconds. Well my car feels like it's missing after now and it idle rough. Do you think that I fryed my Ecm?
Old Oct 22, 2017 | 08:41 PM
zed-028's Avatar
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
Re: Car runs rough after valve cover swap. I think I killed my ecm
sounds more like youve disturbed something vacuum related in/around the covers.
Old Oct 22, 2017 | 08:50 PM
GeneralDisorder's Avatar
No. It wouldn't run if you fried your ECM.
You may have dislodged some spark plug wires or vacuum lines. Start with the basics.
GD
TwoTimeSC
Exterior Parts Wanted
Oct 23, 2017 08:08 PM
