Coolant down lifter valley
Car: 1989 IROCZ
Engine: 305 TPI "F" CODE
Transmission: T5 World Class
I am in the process of replacing all the top end gaskets in an attempt to stifle a wandering idle and stalling issue, when taking the intake base off some coolant spilled into the lifter valley. Not a lot but enough to warrant making a post about it! I'm assuming that I now need to change my oil, correct?
Car: 1989 IROCZ
Re: Coolant down lifter valley
I should clarify that I meant intake manifold gaskets not top end. Will I need to do some sort of a "flush" or will a regular change do the trick?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Clean up the coolant in the valley. Then just do a oil change.
Coolant can destroy bearing!
