Breaking in Melonized Dist. gear
Old Nov 21, 2017 | 06:21 PM
Flip33's Avatar
Car: 1933 Ford Sedan, 1934 Ford Pickup
Engine: 350 Chevy
Transmission: 700 r 4
I converted a L-31 to a carb. which required installing a Melonized gear to run with the roller cam. I know to prime engine and put assembly lube on gear. Can you break in gear with Mobile One oil and do you need to run engine for 20 min. like you would in breaking in a cam. Also with this conversion, what plugs might anyone recommend? Thanks for any and all help
