EVAP Without ECM?...
Subscribe
Nov 27, 2017 | 03:01 PM
Can the EVAP system be set up to function without the ECM?
If so, what must be done?...
Reply 0
Nov 27, 2017 | 03:04 PM
Re: EVAP Without ECM?...
Hook the vacuum line from the evap to ported vacuum and delete the solonoid.
Reply 0
Nov 27, 2017 | 06:26 PM
Wow, that easy? Thanks for the reply...
Reply 0
Nov 28, 2017 | 05:19 PM
Quote: Hook the vacuum line from the evap to ported vacuum and delete the solonoid.
Won't this create a vacuum leak? (Maybe I'm confusing port vacuum??)
Reply 0
Nov 29, 2017 | 08:03 AM
Ported vacuum is above the TB, or before, so it's not a real vacuum leak. It would be working like a venturi in this application and since it is in the intake tract, it would just pull the vapors into the air stream
Reply 0
Nov 29, 2017 | 09:41 AM
Quote: Ported vacuum is above the TB, or before, so it's not a real vacuum leak. It would be working like a venturi in this application and since it is in the intake tract, it would just pull the vapors into the air stream
Yep, I had them mixed up then. Thanks for clarifying.
Reply 0
Subscribe
