89 Formula 350 speedometer reading way off
Old Nov 28, 2017 | 01:28 PM
1983LU5TA's Avatar
Car: 1983 LU5 Trans Am, 1967 Chevelle
Engine: LU5, LSx
Transmission: 700R4, 4L60E
Axle/Gears: 3.73, 3.73
The speedo in my 89 Formula 350 is reading much higher than what it should. I’m running the factory 9-bolt rear with 3.27 gears, stock 245/50R16 tires, and the correct speedometer gears (17 drive/45 driven). It reads around 55mph when I’m going 40. The odometer is obviously way off as well. The only thing that has been changed is the PROM, to a Hypertech. I’ve had 13 thirdgens and never had this happen, at least not while running the correct speedo gears. Does anyone have any ideas or have any suggestions as to what I can check?
Old Nov 28, 2017 | 01:58 PM
Big&BadGTA's Avatar
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
Re: 89 Formula 350 speedometer reading way off
When did the issue begin? And what might have changed right before?
Old Nov 28, 2017 | 02:03 PM
1983LU5TA's Avatar
Engine: LU5, LSx
The speedo has been reading incorrectly since I got the car. It makes zero sense to me. I’ve swapped gears in TPI cars before and the speedo always read correctly after swapping the speedo gears. Everything is right. Even the Hypertech PROM (159311) is correct for the car
Old Nov 28, 2017 | 02:09 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I would swap in a different cluster and retest.
Old Nov 28, 2017 | 03:01 PM
1983LU5TA's Avatar
Engine: LU5, LSx
Can i swap in a 120 speedo for testing purposes? I dont know of any 140 speedometers to swap in place of mine that are local
