Why is there a second bolt tapped into oil pan?
Old Jan 16, 2018 | 01:18 PM
rottweiler68's Avatar
Car: '89 Iroc
Engine: 383 TPI
Transmission: Built 700R4
Axle/Gears: 9 Bolt - 3.45
Why would PO have tapped a bolt into the oil pan. This is a few inches above the drain plug which is perfectly fine? The tapped bolt appears as it's leaking as well.
Old Jan 16, 2018 | 01:27 PM
Drew's Avatar
Re: Why is there a second bolt tapped into oil pan?
Turbo drain.
Old Jan 16, 2018 | 01:30 PM
Car: '89 Iroc
Engine: 383 TPI
Originally Posted by Drew
Turbo drain.
Thanks! So I'm guess the PO removed the turbo and/or line. What is the best way to seal this up? I was thinking something like this sealant and finding the right plug?
Old Jan 16, 2018 | 03:18 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
The right plug and a copper crush washer would work fine. Or some thread sealant
Old Jan 16, 2018 | 03:21 PM
Car: '89 Iroc
Engine: 383 TPI
Cool, thanks!
Old Jan 20, 2018 | 02:57 AM
GeneralDisorder's Avatar
Hard to see much from that pic. Looks like a big mess to me. Replace the pan.
GD
Old Jan 25, 2018 | 11:53 AM
JA411's Avatar
It's the oil level sensor hole that has been deleted.
Old Jan 25, 2018 | 01:21 PM
Car: '89 Iroc
Engine: 383 TPI
Hmmm, that would have been non stock that was added and then removed?
Old Jan 25, 2018 | 01:45 PM
Drew's Avatar
Low oil sensors were used on other GM V8 applications, but can't remember seeing one in a thirdgen. Seems that the threads in those pans used a more substantial boss than just tapping the pan.
Doesn't really matter what it was for, it's not doing anything now. I'd be damn tempted to wait til the next oil change, and while it's drained, I'd clean the snot out of the area, clean, clean, clean it again. Get it as clean as possible, find a plug that will fit right, even if that means going up a size, or using a self tapping drain plug, and then use an auto-rated liquid thread sealant, and run the plug in snug.
This is one case where I'd probably consider cleaning the area as clean as possible, and seal the area with regular JBWeld. Not the JBKwik or whatever they want to call it, but the 24hr set variety. It's not a structural joint, the goal is to end the seepage. It'd be a lot faster than changing the pan, and doesn't cost much. Worst case you might still have to change the pan later.
Old Jan 25, 2018 | 01:50 PM
Car: '89 Iroc
Engine: 383 TPI
That's my plan just to clean it and seal it up, it's actually barely leaking but want it sealed all the way. I was just curious as I had never seen these level sensors before.
Jesse's87Z28
Oct 6, 2008 09:15 PM
hpjspdr4l
Dec 11, 2003 12:32 AM
zr1 32 16 405
Feb 25, 2003 05:53 AM
1986_F-Bird
Jan 7, 2003 07:33 PM
JPrevost
Jan 15, 2002 08:32 AM
