Question
Old Jan 17, 2018 | 06:47 PM
SketchyZed's Avatar
Car: 1991 camaro z28
Engine: 5.7
Question
So i got my intake manifold gasket replaced but before i did i only hand on slow oil leak the rear main seal now after i got it, it is timing cover and i think the front main seal too my oil pressure is really low now i give light throttle in drive i hear knocking, but when i was leaving work i had oil pressure above 30 i didn't hear the noise until it warmed up then it dropped right above the red line.
I just tested it in park still warm i got the noise all the way until i got the oil pressure gauge to 30 then it stopped what could have happened? was it me getting that new gasket installed that caused this or something else?
Old Jan 17, 2018 | 07:09 PM
Drew's Avatar
Re: Question
Wut?
Old Jan 17, 2018 | 08:04 PM
SketchyZed's Avatar
Engine: 5.7
Re: Question
sorry i was in a hurry
Old Jan 17, 2018 | 08:20 PM
zed-028's Avatar
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
Re: Question
Old Jan 17, 2018 | 08:32 PM
SketchyZed's Avatar
Engine: 5.7
Re: Question
I got my intake manifold gasket replaced a week or two ago and after that i have been having low oil pressure and two more oil leaks popped up and a knocking noise that goes away when its cold and the oil pressure is high but when it gets to running temp its starts knocking again could a new gasket cause all this?
Old Jan 17, 2018 | 08:58 PM
Drew's Avatar
Re: Question
Maybe... Could have a piece of old gasket blocking your oil pickup. Or it could just be a coincidence. Do a visual inspection to figure out where the oil is leaking. An engine can go from working perfect one day, to spinning a bearing in a quick hurry. Could have just decided to lay down for no reason relating to the gasket.
Old Jan 17, 2018 | 09:19 PM
SketchyZed's Avatar
Engine: 5.7
Re: Question
okay
'86 350
Carburetors
38
Oct 16, 2007 09:55 PM
easySPEEDcamaro
Feb 26, 2003 07:31 PM
leirch
Nov 28, 2001 12:39 PM
Daz
Apr 29, 2001 01:01 PM
