Mini Starter alignment
Old Mar 30, 2018 | 11:47 AM
Clements408's Avatar
Car: Son drives 1989 IROCZ
Engine: 5.7L TPI, AFR 195, L98
Transmission: 6 spd manual
Axle/Gears: Stock
I bolted up a new Hitachi style mini started to my 350 engine (out of car) to check for alignment and gear mesh. It lines up very well without shims but the starter gear does not retract after I manually pull it out with a screw driver. If I manually turn the engine over slightly, it quickly retracts so just wanted to get feedback if this is normal.
Old Mar 30, 2018 | 12:20 PM
Larry's Avatar
Car: 86 Corvette
Re: Mini Starter alignment
You need room for heat expansion. My FSM says .020" pinion to flywheel clearance.
Duke
Jun 20, 2012 02:32 PM
erummel
84
Dec 3, 2010 08:25 AM
erummel
96
Mar 6, 2010 05:42 PM
speedmachine
Dec 14, 2006 10:57 PM
OUTATIME GTA
Jun 25, 2006 02:37 PM
