Overheating
Overheating
2007 Dodge Magnum is overheating did a coolant flush on 04/17/18 couldn't get the air bubbles out the lines. Changed the thermostat housing 04/17/18. Pressure is still building in the coolant lines backing up in the reservoir.
Re: Overheating
You're not gonna get a lot of help here, as this is a 82-92 Camaro and Firebird forum. ....that being said I'd start by removing the thermostat entirely and confirm that the coolant is actually flowing through the system.
Good luck.
Good luck.
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Re: Overheating
You wont read this since you now know this is a camaro/firebird board lol
Last edited by Pro; Apr 18, 2018 at 07:56 PM. Reason: better include the firebirds
Car: 1991 Camaro RS
Engine: Hot 355ci
Transmission: Beefed TH350
Axle/Gears: 4:10
Re: Overheating
Did you bleed the system for about 20 minutes (fully warmed up)? If it's not 100% bled then there will be air pockets in the system causing over heating. I also recommend replacing the radiator cause it's probably caked with crap.
