Code 42 possible solution
Old Jul 8, 2018 | 11:56 PM
SARswmr's Avatar
I was getting a code 42 after my T56 swap. Trans swap had nothing to do with it just when it happened. Chased wires for a couple hours with my meter and test light following the test tree for that code. Couldn't find anything and just as I'm about to pull the ignition module I discovered the 4 pin connector plug housing is cracked pretty good... Just to rule it out I de-pinned that plug from a spare wire harness and replaced the cracked one. Problem fixed instantly.
Sharing just to see if it helps someone else...
ghettocruiser
Jan 25, 2017 09:06 PM
seanof30306
Dec 12, 2005 08:32 PM
biff85ta
Sep 9, 2004 08:39 AM
Stekman
Sep 5, 2004 12:33 PM
