DTC with engine running?
Old Aug 20, 2018 | 10:27 AM
Strange's Avatar
Car: 92 RS Heritage Edition
I know typically you don't try and pull codes while the engine is running and even for live data you plug the scanner in before you start the car. That said, The previous owner of the vehicle apparently has wired ECU power to the ignition cylinder and I'm not exactly comfortable enough with wiring to go hunting for that little gremlin to undo it. So I'm wondering how dangerous it is to shove a paperclip in the OBD port with the engine running? Every time I turn off the engine to check the code it just clears the ECU. Opinions?
Old Aug 20, 2018 | 06:16 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: DTC with engine running?
Won't work, with a running engine the SES/CEL is used to indicate lean, rich, or open loop. Only at key-on, engine-off does the ECM blink the codes.
RBob.
Old Aug 21, 2018 | 06:47 PM
Yup, sounds like it's time to find and undo the PO's "improvements".
Old Aug 21, 2018 | 08:49 PM
Strange's Avatar
Yea something was telling me that's my only option. Not the only "improvement" that needs to be undone...like the T junction in the exhaust...but anyway thanks guys I appreciate it
25th327RS
Feb 17, 2013 09:36 PM
DMATESIC
Dec 28, 2001 07:33 PM
BAD BLACK WS6
Aug 14, 2001 11:07 PM
87kevroc
Apr 13, 2001 06:39 PM
