Change to bronze distributor gear?
Car: 1934 Ford Roadster
Engine: 350 CSB
I'm using an after market HEI distributor from Skip White in my CSB factory roller block.
Last season I changed to an after market hydraulic roller cam from Howards Cams. Item number 183215-14.
Should I change to a bronze/composite gear on the distributor?
Engine: 4++,350 & 305 CIs
Re: Change to bronze distributor gear?
I have comps composite gear on my small cap HEI, had to make a small shim to make it fit the smaller shaft but no complaints so far.
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Only if the cam is made of forged steel. If it's cast iron, run the stock iron gear...
pound
Feb 26, 2014 08:20 PM
