84 camaro berlinetta
Car: 02 avalanche and a 84 camaro
Engine: Putting a 305 in it
Transmission: Automatic sadly
Hey guys I知 new to this forum but I have a 84 berlinetta with the space age dash. And the motor I had is the v6 but I知 doing a engine swap with a 305 from a el
camino. And I need to know what psi fuel pump I should get. I was thinking possibly 10
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
Re: 84 camaro berlinetta
standard block pump will do - check the summit website. all the mechanical return ones are pretty similar.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
if the old motor had the mechanical pump (looks like it did) with the feed and return line going to it, use the carter 6626, pocket change from Rock Auto.
Camaros4Life
Jun 26, 2009 03:59 PM
Camaros4Life
Dec 19, 2008 01:35 PM
