SBC timing cover help please
Old May 17, 2019 | 07:58 PM
jaystoy's Avatar
Had to replace the cam and lifters in my sons camaro. It's an 84 350. Anyhow, I pulled the timing cover relatively easy. Did not have to touch the oil pan. Now trying to get the cover back on??? It has that thick rubber seal and its impossible `to get the cover on. I hate to begin loosening oil pan bolts, gonna create another issue. Any advice or help?? I did trim the two corners of the cover as many do
Old May 17, 2019 | 09:24 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: SBC timing cover help please
There are 2 different front cover seals depending on the oil pan. One pan uses a thick seal. The other uses the thin seal.
It is possible to install the cover with the oil pan on but is also very difficult. Usually you need to modify the inner seal lip of the cover (trimming the corners). Unless you've done it before and know what to do, it's best to drop the pan down to get a good alignment on the front pan seal.
Old May 17, 2019 | 09:55 PM
jaystoy's Avatar
Thank you! I did trim the corners, as I saw this on youtube....however, it has not really helped, and no, I have not done this before. I suppose I will need to loosen the pan....but ugh....hate to introduce more options for leaks. Anyone ever just toss the rubber lip seal, and have success with a nice thick bead of "the right stuff"
Old May 17, 2019 | 10:25 PM
92RS-HeritageEd's Avatar
Car: 92 RS / 90 IROC-Z
Engine: 305 / 350
Axle/Gears: Non-Posi / Posi - Both GU2 - 2.73
I also ran into this issue. Post # 41: The easiest (safest) thing to do though is to loosen the oil pan bolts and drop it just enough to clear the lip...
Old May 18, 2019 | 08:43 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Don't do this.
Besides the fact that the cover will leak, you stand a good chance of getting excess silicone into the oil pan where it will clog the pump pickup. Instead, loosen the pan bolts to allow the pan to drop low enough to let you install the front cover with the proper seal. A SMALL dab of silicone at the corners will help insure no leaks.
DarrensCamaro
Jan 22, 2014 01:25 PM
Mr_YuK
Jun 23, 2011 05:02 AM
mesterious
Feb 8, 2011 09:33 PM
Kurt04
Jan 22, 2009 10:06 PM
Kurt04
Apr 5, 2008 03:42 AM
