1991 Z28 TPI
Old Jun 12, 2019 | 08:24 PM
Kenny Quintero's Avatar
1991 Z28 TPI
Hello Everyone!,
I just picked up a 91 Z28 from my neighborhood as a project. The car has an issue accelerating. It runs and starts and you can give it a bit of gas before it bugs down and tries to cut off... If you push on the gas like you normally would it wants to shut down. If you kind of easy the pedal little by little it kinds of let you accelerate some up to 3500 RPM no higher than that. Is not missing either that I can tell. The car will not drive since you can't accelerate. Things d=one so far flushed the gas tank, new fuel filter, new plugs, new alternator, ANY help tracking this bug would be awesome! Thx!
Old Jun 12, 2019 | 08:31 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1991 Z28 TPI
What’s your fuel pressure at ?
Have you ohmed your injectors cold and hot ?
Old Jun 13, 2019 | 06:34 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: 1991 Z28 TPI
Catalytic converter may be plugged. Much exhaust coming out of the tail pipe? Could also be fuel pressure and/or injectors like Tuned Performance mentioned, or distributor problem i.e. ICM, pickup coil etc.
tricken-rides
Sep 18, 2018 04:11 AM
SARswmr
Apr 17, 2010 02:42 PM
pjleavitt
Jul 13, 2009 12:51 PM
scorp508
Aug 21, 2002 08:10 AM
